Sponsored by: CARiD
no park
Old Dec 26, 2006 | 07:39 PM
amyrick23's Avatar
5th Gear
Default no park
Transmission on the discoII will not shift into park?[&:]
Old Dec 26, 2006 | 08:07 PM
ScottM's Avatar
5th Gear
Default RE: no park
pry off the shift selector trim piece. there is a little 'C' clip that goes around teh lift shaft and secures the shift button. Those sometimes break. They are about 50 cents at ACE hardware to replace. Once the lift **** is exposed in a pinch you can just grab it with your fingers and change geats to move the vehicle.
The other culprity can be the brake pedal switch which is a saftey switch on the pedal column and these fail without warning and immobilize the shift motor. they are about 15.00 to replce form Pep boys or Merles, it is an AC delco part used on all sort so of american models too. form teh facny rover parts suppliers it is about 60 bucks.
Beyond these two items, broken linkage cable or something worse.
Good luck.
Old Dec 27, 2006 | 05:40 AM
amyrick23's Avatar
5th Gear
Default RE: no park
Thank you ScottM I will check those out tomorrow morn.
Anthony
Old Dec 29, 2006 | 06:51 PM
amyrick23's Avatar
5th Gear
Default RE: no park
Anthony here again. Can anyone give me a little more help with this trans shifting problem? I have ruled out the shifter and cable as I disconnected the cable and shifted the trans by hand into park but when I try to adj for park I then cannot put into 1st???
Old Dec 29, 2006 | 09:10 PM
Default RE: no park
Sounds like you may need a new cable.
Mike
amer_qureshi
Jul 10, 2024 02:03 PM
disco12
Feb 16, 2006 10:56 AM
Cirrus
Jul 27, 2005 10:51 PM
Dhwright
Jun 11, 2005 12:23 AM
felixx23
Jun 2, 2005 12:05 AM
