No rear brakes!
No rear brakes!
I've been having problems with a soft pedal on my D1 since changing pads several years ago (don't drive it much). Bled the system several times, which improved it a bit, but not perfect. Now, after bleeding the brakes recently, I've got good front brakes but I've lost the rear brakes completely. Pad and rotors are still good, the master cylinder has been bled but found that no fluid is coming out of the modulator. Do I have a bad modulator or is there a step missing here? Thanks in advance for any advice.
Might even try to bleed the line from the MC to the modulator. I don't recall how the D1 is setup, but on my D2 when I had the modulator out for a little while, all of the fluid drained out of the lines and I couldn't bleed it at the wheels until I bleed the lines coming out of the MC, but I didn't remove it to bench bleed it, I just bleed them where they went into the modulator.
elguappo999
11-16-2006 04:48 PM
