Sponsored by: CARiD
No start!!! Please help me out!!
Old Apr 9, 2010 | 11:42 PM
andy@aacstyle's Avatar
3rd Gear
Default No start!!! Please help me out!!
Ok guy's I really need help asap on this one, I own a 96 Disco,I would be driving and intermittedly it would die, I put it in nuetral turn it over and it would start right up, hot,cold whatever didnt matter. This morning I go to start it and no start, turns over fine, gas to the floor or no gas at all makes no difference, I check fuel pump, works properly, I have fuel pressure and all. I check spark, and Ive got nothing, I check all connections, everything is good, check all fuses and relays, all good, I am stumped! ANY IDEAS??
Thanks in advance
Andy
Old Apr 10, 2010 | 08:02 AM
Have you checked for fault codes? Never try and start it with the throttle to the floor, you are messing with the ECU at that point and causing problems.
One thing that will cause this is a bad crank sensor.
Old Apr 12, 2010 | 09:12 AM
3rd Gear
Awesome thanks mike, Ill check it out today!! Thanks again.
ooh1
May 19, 2013 04:38 PM
sawadeh
Jul 2, 2011 08:10 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
