No Starting with fuel pressure showing good 30 pds
Just finished the first leg of a long two way trip and went out this morning and truck not starting. I have a fuel pressure gauge installed and it is showing 30 pds of pressure, so I think it is ignition or spark and not fuel pump or fuel filter..
I am not at home with all my resources so any direction on trouble shooting would be of great help.
Its a 95 D1 3.9 dizzy engine.
I'm getting my head in testing mode gear. Went through this about 5 years ago. I am Texaninmass on LRO..
Ignition system test - Page 4 - Land Rover Forums : Land Rover and Range Rover Forum
Trying to find the test procedures that I now remember from this article. I just downloaded the 95 Shop manual here locally, so hopefully they will be easy to find.
Drowssap...it's pre-OBD. Really a 94 production truck.
Both times it started right up and ran for several hundred miles before mis-behaving the second time. Also got big suck on the gas cap both times. The second time I left cap loose.
- I am going to run the codes..
- Test the coil
- Find the test instructions
- Headed over to a salvage yard this morning to pull everything I can think of off the ignition on a same model Rover.
- Replace fuel filter (I don't think its the pump because of the good pressure)
She has run for the last year that I installed the fuel pressure gauge at 27 to 34. I put a replacement fuel pump in her about 2 years ago. Finishing up at salvage yard and will replace filter as soon as I return. Dont' think it's the issue but I have a new one so it can't hurt. been about 3k since a changed it
