Sponsored by: CARiD
noise from fan belt area
Old Feb 22, 2007 | 09:27 AM
Ipod's Avatar
Default noise from fan belt area
I have a strange whistling /squeakingnoise coming from the fan belt area of an old disco. I have changed the fan belt tensioning wheel bearing but there is still a noise. I think it could be the water pump?
Has anyone any ideas? What happens if the bearing goes in the water pump housing? Or could it be something to do with my alternator?
Old Feb 22, 2007 | 10:58 AM
Landzu's Avatar
Default RE: noise from fan belt area
When my water pump was going out it wined like a small super charger.
Old Feb 22, 2007 | 09:37 PM
geoman's Avatar
The water pump bearing in the snout of the casting will make such a noise before failing. The next step--after the initial noise--is thatthe radialdisplacement of the shaft causes the seal to leak, and this is when you will see coolant stains, and then dripping ---out of the weep hole on the underside of the snout casting.Up to this point, the repair cost is modest --- in requiring a water pump, gasket, serpentine belt, and coolant.
If you still procrastinate-- the pump impeller will now start to move fore and aft ---- and it WILL (fairly quickly) grind a hole into the front timing case cover, and that is a part that costs $600 or more (the labor adding on another $200--or more).
So check it out NOW. With the engine off (of course) take the fan with both handsat the 3 o'clock and 9 o'clock positions -- and try to "rock" the fan by alternately pushing with one hand while pulling with the other. If you have mechanical play there --- time to change the water pump.
regards,
Geoman
www.eurotekapg.com
Old Feb 24, 2007 | 12:12 PM
Ipod's Avatar
Thanks all sorted now. Just swapped the water pump and all sounds quiet now.
kenrickgsxr
May 1, 2014 08:58 AM
RustRover
Sep 14, 2012 06:02 PM
Thatdudeuno1
May 1, 2012 05:10 PM
undertaker
Dec 26, 2008 09:25 AM
