Sponsored by: CARiD
O2 sensor missing signal
Old Sep 22, 2013 | 02:00 PM
onewingman's Avatar
Default O2 sensor missing signal
previous owner in a fit of rage pulled the wiring out of the plug, pass., side.
I replaced the sensor...but, the signal has vanished...The assumption being that the female/harness receptacle was damaged in said fit of rage...attack. Now, we know, there is nothing in the engine bay that is NOT in the way of accessing that plug...I'm hoping, someone might have a bit of insight on how to get to the plug and figure out which wire and/or wires are the damaged ones...
My thought is dig my way in there, with a replacement socket in hand and just replace the original... just looks like almost everything on the pass side of the engine's gotta come out...
All suggestions welcome. Thanks in advance.
Old Sep 22, 2013 | 09:24 PM
We kinda need to know what model and year and engine it is.
Old Sep 23, 2013 | 06:01 AM
onewingman's Avatar
Default Missing o2 signal
No doubt the yr &model would be helpful...2000 Disco, 4.0...Ooppsss...
Old Sep 23, 2013 | 07:30 AM
Perhaps these would help.
File Type: pdf
File Type: pdf
Old Sep 23, 2013 | 07:59 PM
If the connector on the truck is all jacked up you can splice the wires together, its not ideal but it'll work.
Old Oct 5, 2013 | 09:37 AM
onewingman's Avatar
Final update/outcome...upon reviewing my notes...I had this problem before...the plug got a little oil in it...I guess...no oil leaks to be found...but anyways...
I took it apart and flushed it out thoroughly w/ brake cleaner, applied a bit of dielectric grease to both 1/2's, put it back together and problem solved!
Thanks for the suggestions
Old Nov 17, 2013 | 03:55 PM
RSPTex's Avatar
I was looking for this! I'll link the exact image (I'm looking for the driver's side front O2 sensor) back to the thread I was posting in.
Old Dec 8, 2013 | 04:36 PM
onewingman's Avatar
Smile MISSING O2 SIGNAL revisited
Shoulda posted this way back when...buy, sorry got distracted...In any case, I was thinking back, at that time, and remembered having the same problem...and the solution...which in all fairness, I do believe I got here!...IAC, slight valve cover seepage compromises the conductivity of the connector...
Solution: can of brake/carb cleaner, dilectric grease. Open the connector, aim the carb cleaner at each part of the connector, in turn, close eyes, mouth, ears...and blast away, when it looks sparkly clean in there, hit with a bit of compressed air, liberally apply some dielectric grease, to both halves and reassemble...
Far from rocket science...but, worked for me...
Now, the only thing I have to do on this is GET RID of my NEW BOSCH O2 sensors and replace them w/ Genuine Rover O2 sensors...ain't that the ****s!!! They don't read properly, neither does the EXPENSIVE AFTERMARKET MASS AIRFLOW and COOLANT TEMP SENSOR... NONE of them work properly...cleaver those FLIPPIN' ENGINEERS!...
Other than that, Merry Seasonal Type Greetings!!!
Old Dec 9, 2013 | 11:17 AM
RSPTex's Avatar
We've had about 1.5' of snow in Utah, and I don't have a garage, so I still haven't taken care of my issue. I think I will both rewire the sensor back from the ECU and clean out the connectors really well. I still get those stupid P0134 and P0150 codes. Really annoying, but the truck runs great. It has been a champ in the snow and seems to enjoy the snow, even... Didn't know these things had attitude. My Ultragauge is pretty nice to see everything, but I think I'm going to swap over to the iPhone-based one that was just released. It does bit better job of data logging and gives more details on trouble codes. I'll reply here when I get my problem fixed.
Old Feb 23, 2014 | 01:03 PM
onewingman's Avatar
Het, Tex, don't kn ow if this'll get to get to you...but, DON'T re-wire if you have NON OEM/FACTORY/AUTHENTIC ROVER O2 SENSORS...It's not that hard wiring never fails...just not OFTEN! and the odds of BOTH SIDES FAILING at the same t6ime are astronomically LOW!...the only ones that read correctly are the OEM's...gee, think the bean counters thought that one up...true with all the sensors...
Which now brings us to the SEARCH of a DECENT PRICE on OEM'S...anyone gotta line on them?
Thanks
KlamathMatt
Apr 17, 2020 05:27 AM
LRLawyer
Mar 17, 2014 10:22 PM
Scott R
Dec 25, 2009 03:43 PM
hoberock
Jul 18, 2006 10:24 PM
