Sponsored by: CARiD
Oil Pan Gasket
Old Aug 27, 2008 | 10:08 PM
old gold's Avatar
Default Oil Pan Gasket
I am in the middle of a head gasket replacement (98 discovery) and decided to remove the oil pan to get a look at the bottom end.
All looks well. Should I put in a gasketw/ sealant or go with just the sealant?
I have seen mixed signals. I used strictly the sealant on my VW oil pan and that worked fine.
Also should I do anything with the oil pickup while it is accessible?
Old Aug 28, 2008 | 01:02 AM
CandiMan's Avatar
Default RE: Oil Pan Gasket
ORIGINAL: old gold
It's a personal preference. For me I used a gasket. The cork gasket I got from British Atlantic was a tad bit bigger than the pan. But onceI installed all the bolts and carefully tighten them equally, it contoured the oversize gasket to the exact shape of the pan.If you understand what I'm saying.I remember when I drop my oil pan (also a 98 like yours) I had to also drop the tie rod linkage in order to have enough clearance for the pan. If you think you can install the pan without distrubing the bead of silicone, then use the silicone. If not, then use a gasket.
Old Aug 28, 2008 | 06:57 AM
old gold's Avatar
I swung the sway bar and the tie rod out of the way so it is a straight shot onto the engine.
mike111
Jun 2, 2014 08:58 AM
jpmiller
Sep 26, 2012 06:32 AM
afphinfan
Jan 5, 2008 11:04 AM
91rover
Jun 13, 2007 03:15 PM
modelwerks
Oct 13, 2005 05:39 AM
