Sponsored by: CARiD
Oil Pressure Light will NOT light up?
Old Apr 21, 2008 | 09:28 AM
dinandan's Avatar
Default Oil Pressure Light will NOT light up?
Hello,
My oil pressure warning light willNOT come on. When I turn on the ignition the light does not light up as all the other dash lights do. I’ve check the bulb (it works in other dash light sockets) and even unplugged the switch near the oil filter and the light still doesn’t come on. Somewhere between the switch and light has the wire become grounded? Where do I start to look for the solution.
Background: 1991 Range Rover (180k miles) with a 95 defender engine (80k miles). My oil pressure light was flickering last week so I changed the filter and cleaned the drain pan (it was already clean but I did it again anyway). The Light still flickered so I did an ATF flush. When I went to start the engine with the new 10w- 40 the oil pressure warning light wouldn’t come on.
Any helpful info on this issue would be greatly appreciated.
Thanks,
Dan
Old Apr 21, 2008 | 02:05 PM
Phototone's Avatar
Default RE: Oil Pressure Light will NOT light up?
Oil pressure sending units can fail. Have you checked that?
Old Apr 22, 2008 | 08:24 AM
dinandan's Avatar
Phototone,
Do you mean the switch or is the "oil pressure sending unit" something diffrent?If the switch is unplugged the oil pressure light should come on...right?
Thanks,
Dan
Old Apr 22, 2008 | 04:22 PM
fourplay's Avatar
3rd Gear
Replace the switch by the the filter
Old Apr 23, 2008 | 09:17 AM
dinandan's Avatar
I did nothing to fix the problem but now the light works as it should. Great! An intermittent electrical issue. I'm starting to understand why Lucas was called the Prince of Darkness.
Thanks,
Dan
PS The new oil pressure switch has just under 1000miles on my truck.
drewski
May 31, 2013 10:50 AM
srockrae
Sep 3, 2012 06:08 PM
gulfcoastgorilla
Apr 7, 2012 05:11 PM
eaglewing
Apr 16, 2011 11:06 AM
DooDer
Jan 12, 2010 10:46 PM
