Sponsored by: CARiD
oil temperature
Old Aug 30, 2007 | 09:02 PM
fred147's Avatar
Default oil temperature
help please. ihave an 1983 range rover 3.5ltr with an oil prob.
i have 40-60lb pressure but i only have to drive about 3-4 klms to have the temp go to 240-250 deg F.
the water temp only 1/3 up scale. i replaced the gauge and sensor with an aftermarket vdo type but reads exactly the same. has anyone struck this problem before?
Old Aug 31, 2007 | 07:40 AM
Default RE: oil temperature
So are you saying your oil temp is running in the 240 range?
If so, I would look more at the coolant system, it is not the oil's job to disipate the engine temp, that is the coolants job. I would suggest you look and replace the t/stat, if that doesn't settle the heat down then go to a radiator shop and have them check your radiator for blockage, may need to be cleaned out.
cimca514
Aug 30, 2011 03:04 PM
Bundu
Aug 2, 2010 12:03 PM
Robmcin
Apr 17, 2009 03:17 PM
Terry W
Dec 25, 2007 01:22 AM
unco
Feb 1, 2007 11:19 AM
