Sponsored by: CARiD
oops.... was pulling front drive shaft ........
Old Jan 23, 2010 | 03:54 PM
jonesprops's Avatar
8th Gear
Unhappy oops.... was pulling front drive shaft ........
and i think i did something really dumb had disconnected the shaft from the front differential.
couldn't get at the last bolt on the transmission side and decided to just put it in gear and pull forward in inch or 2..... a loud thumping and now no forward motion or reverse and makes a ratcheting sound when placed in park .....
how bad???? new trans??? thanx in advance for any responses. 2000 disco II
Old Jan 24, 2010 | 09:45 AM
Rovin4life's Avatar
wow, stupid. but if it thumped the trans take the pan down and pray to god it only destroyed a few things.
if not its a new transmission.
Old Jan 24, 2010 | 11:47 AM
jonesprops's Avatar
8th Gear
Default update to oops. thanks everyone
So turns out nothing is busted. i got a little confused. had read that if you lock the cdl you could drive on the rear shaft only, confused the transfer case with the cdl anyways long story short it only turned a few rotations and did no damage. found new greasable u joints at pepboys for $12.99 neapco 1-0005 the dealer wanted $118.
Old Jan 24, 2010 | 01:38 PM
yesmar's Avatar
glad it worked out for you.
those u joints sound like a deal, ill have to swing by pepboys and poke around.
Old Jan 24, 2010 | 06:03 PM
antichrist's Avatar
Make sure the u-joints say on them Made in USA. There are some china ones that use the same Neapco PN.
Don't forget your centering kit also.
Old Jan 24, 2010 | 08:42 PM
rj95lss's Avatar
Also, next time just put the t-case and tranny in the "N" position and get back under there and you can rotate the drive shaft by hand to get to whichever bolt you still need to get to...
Old Feb 1, 2010 | 06:15 PM
jonesprops's Avatar
8th Gear
Smile Stamped USA made in pittsburgh
Oh and they were $11.99 not $12.99 at pep boys part #1-0005 and thanx for the advice on manually rotating propeller shaft.....IE trans and transfer case in neutral.... Probably won't do that again
Old Feb 1, 2010 | 06:23 PM
jonesprops's Avatar
8th Gear
Talking Stamped USA made in pottstown Pennsilvania
Oh and they were $11.99 not $12.99 at pep boys part #1-0005 and thanx for the advice on manually rotating propeller shaft.....IE trans and transfer case in neutral.... Probably won't do that again. Sorry did not have my glasses on in the previous post and mistakenly posted pittsburg. and the grease nipple is tapped into the top of one of the bearing caps.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
bamarover
Dec 26, 2007 05:24 PM
05LandRover
May 9, 2005 01:02 AM
