Sponsored by: CARiD
Over tighten transmission bolts
Old Sep 12, 2012 | 11:04 PM
JRover83's Avatar
5th Gear
Default Over tighten transmission bolts
Hey all,
I recently performed the 90k transmission service on my 2003 Disco 2 and when I replaced the transmission pan I tighned the bolts to 30 - 40 ft lbs. later I found it was only supposed to be 8 lbs. it's not leaking, but should I be concerned? Can I loosen and re tourqe? Or do I need to get a new gasket and start over?
Thanks everyone!
Old Sep 13, 2012 | 07:54 PM
Not leaking?
Dont worry about it.
Old Sep 14, 2012 | 07:14 AM
drowssap's Avatar
Better off leaving it for now
Old Sep 18, 2012 | 05:14 PM
JRover83's Avatar
5th Gear
OKay thanks guys... Learned my lesson, read the manual first.
Old Sep 18, 2012 | 05:37 PM
LR Techniker's Avatar
If its not leaking, leave it be. If you loosen and re-torque, you will need a new gasket, as the current gasket has already been compressed. I'm really surprised that at 40 lbs, none of those little bolts broke!
Popsickle
May 30, 2013 07:56 AM
vALEXv
May 27, 2012 12:11 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Classklown90
Sep 16, 2010 02:59 PM
4x4master
Jun 3, 2006 11:54 PM
