Sponsored by: CARiD
Overheating/Swishing Disco II
Old Mar 16, 2010 | 10:30 PM
rightsandlefts's Avatar
5th Gear
Default Overheating/Swishing Disco II
Hey guys, 2001 Disco II with 86k miles is overheating. Changed the Waterpump, a few hoses and the thermostat about 6 months ago. No problems for a while. Recently got some swishing noise from the heater core. Now, it'll heat up to normal op temp, but the heat's still blowing cold, then will overheat and the reservoir is extremely hot. Got some pressure noises coming from the thermostat and heater core areas too. Looked around on the forums a little and found some similar questions but not really an answer.....thanks.
JE
Last edited by rightsandlefts; Mar 17, 2010 at 02:45 PM. Reason: added mileage to vehicle
Old Mar 17, 2010 | 06:34 AM
Rovin4life's Avatar
check for leaks. it goes low cause of the leaks.
Old Mar 17, 2010 | 07:49 AM
hilltoppersx's Avatar
how many miles on your truck? when was the last time you changed the thermostat? you need to bleed your system and add coolant.
sideshow
Oct 28, 2012 11:08 PM
Tom Condon
Oct 19, 2006 08:22 PM
procurbusa
Aug 14, 2006 03:19 PM
forbin10
Dec 1, 2005 07:55 PM
bakerww
May 24, 2005 09:35 PM
