Sponsored by: CARiD
P1171
Old Apr 4, 2010 | 08:36 PM
frd1419's Avatar
5th Gear
Default P1171
I have a 99 Disco II with a P1171 that just came on. My milage is 92000. I have not done any real work on it in the year I have owned it except changing the MAF when I got codes a month after buying it, the milage then was 89000. I read other posts, but the seem to have other codes with them not just one. Any ideas?
Old Apr 4, 2010 | 08:39 PM
hilltoppersx's Avatar
what type of MAF did you put in?
Old Apr 5, 2010 | 12:11 AM
frd1419's Avatar
5th Gear
Default Maf
Got it from the dealer
Old Apr 5, 2010 | 06:49 PM
Rovin4life's Avatar
maf codes only cause
four codes. 0171,0174,0172,0175 and two in trans ecu 0734,0733
that lean code is caused by an actual lean condition. can be broken exhaust studs. broken exhaust manifold. leaking intake gaskets.
seen the upper part of the cat at the flange rot a bit causing the problem as well as the lower intake causing an air leak and sucking in oil at the same time.
Old Apr 15, 2010 | 03:32 PM
frd1419's Avatar
5th Gear
I am now hearing a whistle noise on deceleration from the drivers side rear of the motor? It changes pitch with throttle. What is back that way to cause this. I reset the check engine light when I read the code and it has not come back in a good week.
Old Apr 15, 2010 | 03:36 PM
sounds like you have an air leak somewhere.
BIG g
Jun 17, 2014 04:33 PM
03DiscoSE
Jun 8, 2012 07:37 AM
seamuspg
Apr 5, 2011 08:50 AM
jm12503
Jan 24, 2011 09:34 AM
steinj
Jun 29, 2007 05:58 PM
