P1412 & 1415 trouble codes
OK, my check engine light has been on for a while. Two codes were the o2 sensors and evap pump. First o2 sensors. Fixed. Then evap pump. Fixed. Thought I had everything and it stayed off for 85 miles and it came back on. Now the codes are 1412 & 1415. Air injenction pump? I am unfamiliar with this. Anyone have any knowledge on it? Thanks
As long as you dont have to remove the firewall pipe (and it doesnt sound like you do) SAI stuff isnt that bad at all. It is all right on top.
I had those same codes on and off. Spraying down the inside of the solenoid/valve with electrical/brake cleaner got the frequency of them down to less than once a month.
