Sponsored by: CARiD
p38 engine change 4.0 to 4.6
Old Sep 28, 2008 | 11:47 AM
robtopdog's Avatar
3rd Gear
Default p38 engine change 4.0 to 4.6
Hi can anyone help please, ive got a 2000 4.0 rangie with a dead engine, im about to buy a new 4.6 short block! Do i need any other bits or will it be a straight swap.
Old Sep 28, 2008 | 12:15 PM
Default RE: p38 engine change 4.0 to 4.6
What is wrong with the old engine?
Why a new 4.6, short or long block, they are worth more then the truck. Why not find a good used one and save some money?
Old Sep 28, 2008 | 12:22 PM
robtopdog's Avatar
3rd Gear
The old block has cracked liners, low oil pressure, and smokes like a goodun. Its covered 124000 miles and half of that on lpg. Priced up a replacement against rebuild and new top hat linners and new is cheaper.
Old Sep 28, 2008 | 01:18 PM
So find a used short block, you will be alot better off.
Old Sep 28, 2008 | 02:15 PM
robtopdog's Avatar
3rd Gear
Ok even if i find a second hand 4.6 short block it would be really good to know if the parts from the 4.0L will 42d engine will fit and work on a 46d engine ie sump, heads ancilaries ecu ect.
mln01
Jun 12, 2014 07:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
thechidz
Jan 12, 2010 10:54 PM
v35atc
Dec 30, 2006 01:37 AM
