Paint Flaking off Door Handles - 2002 RR HSE
jcutter -
This is a common problem. I had it on my '03 although not as bad. Im the second owner and it would have been covered under warranty but the previous owner never asked for any remediation. Too bad for me.
I corrected the problem myself. The original paint on mine was enamel. I used a lacquerbase and clear coatand and it blistered, therefore I had to remove the entire paint system. and redo from scratch. It looks mint again and only took a few hours.
Make sure if you need to do this you get a stripper that is safe for plastics.
Bob
Bob
Thanks all! I found another FAQ showing a how-to with Bulldog paint adhesion promoter and autotouchup base and clearcoat paints.
Now the only question is how to remove the outside door handles with the least amount of work. I've done it before on Chevy's, but I am guessing that the panels are a little harder to remove on a RR. If anyone has any links to other how-tos on removing the door handles on a 2002 RR please post a link.
Thanks.
Thanks.
