GEMS & BOSCH LR V8's run fine on Platinum/Double Platinum or Iridium Plugs. I've used NGK with great results along with the Autolite Platinum/Iridium Plugs. It's the Bosch stuff you'll want to avoid with the 2x or 4x setup or where the electrode is flush with the insulator.
Be particularly careful with plug #8 (rear passenger) as the exhaust manifold can impede some of the larger plug sockets and you can wind up cross threading the plug.
good info. Now if it will stop raining so I can get to work 🤣🤣🤣🤣
