Sponsored by: CARiD
plug wires trouble
Old Sep 26, 2010 | 04:57 PM
Endshock's Avatar
5th Gear
Default plug wires trouble
I changed the plug wires cap and roter on my 95 disco. Dist cap wouldnt seat so i put the old back on but opted to change the wires . Now it wont start. Its getting fuel (I can smell it starting to flood), but weak spark .
Coil(?)is my guess, but i did finsd a fuse blown under the dash . The fuse block under the hood shows all fuses to fuel pump and injectors fine . Could the plug wires be wrong , 7mm and yes i checked the firing order 15 times . ???? any ideas ???? it cranks fine and almost wants to come too life but nothing... Endshock
Old Sep 26, 2010 | 11:22 PM
Marcoadieter's Avatar
Maybe check the dist cap connection. Thats the main thing you changed, perhaps dist cap not seating had something to do with it.
Old Sep 27, 2010 | 07:44 AM
Those distributors are pretty weak and will fail, especially when you tug on the rotor to remove it.
Old Oct 2, 2010 | 06:53 PM
Endshock's Avatar
5th Gear
Think i should just replace the whole distributor.I'm ok with that it was going to done anyway not yet but well its as good a time as any . any idea what is better to replace it with ? stock, proline or ??? id rather bullet proof all my fixes instead of bandaid . any thoughts. thanks Endshock
Old Oct 3, 2010 | 07:01 AM
They are not cheap, and I hate to have you spend a bunch on my hunch but they have had their problems. If you go that way, make sure to shop around on-line for the different ones and prices. If you have any question, get back to me.
Old Oct 5, 2010 | 09:05 PM
Endshock's Avatar
5th Gear
Thnx mike im going to swap out the lot , just not all at once. the block has great comp. so it stays . what is a really good -awsom distributor . shipping overseas not a problem . i have patience and in no hurry . i want to to this build correctly. (so dose the wife). what is a proper swap distributor for 3.9l for reliability ? thnx all Endshock
mikedemet
Jan 29, 2021 02:02 PM
Discodaisy
Sep 8, 2018 10:26 AM
Matt_Attack352
Jan 13, 2014 09:55 AM
crumleyjc
Jul 13, 2012 01:57 PM
kfordric
May 30, 2005 11:29 PM
