Sponsored by: CARiD
power stearing
Old Dec 28, 2010 | 08:28 PM
CRFCrazy's Avatar
Default power stearing
Im fifteen and I have a 1996 land rover discovery. it started leaking powerstearing fluid lake crazy around the pittman arm on the bottom of the power stearing box and i was wondering if it is worth trying to replase the seal around the pittman arm or if i need to just replace the whole power stearing box. if you have any advice please help.
Old Dec 29, 2010 | 06:50 AM
Depends on how many miles on the truck, if you can get a replacement seal kit and how mechanical you are.
Sure worth a try .
Old Dec 29, 2010 | 08:32 AM
CRFCrazy's Avatar
I found the seal kit at a local dealer for about $75.00. does that sound about right? are there any special tools needed to pull the old seal or install the new one?
Old Dec 29, 2010 | 09:12 AM
XCELLER8's Avatar
you can probably CAREFULLY pry out the old seal , the problem will be getting the pitman arm off to get at it......you'll need a puller
Old Dec 29, 2010 | 06:50 PM
lordmorpheus's Avatar
I know O'Reilly Auto parts has a pitman arm puller in their rental tool section. I imagine most autp parts stores with a similar tool rental program would have also.
LRD2&ME
Sep 2, 2011 08:28 AM
LRD2&ME
May 26, 2011 09:42 PM
tibyABv6
Jun 21, 2009 06:12 AM
thehosst
Jun 5, 2008 08:44 PM
stevenramsey
Apr 16, 2007 12:36 PM
