Sponsored by: CARiD
Power steering out but at least my arms are getting ripped
Old Jul 20, 2015 | 06:51 PM
Lawgirl's Avatar
Default Power steering out but at least my arms are getting ripped
Hey all
Soooo.....I was driving down the road and I heard a sound that at first seemed like fluids were dumping, then it sounded like I ran something over and BOOM. No power steering. Land Rover disc 2 2000....I did not notice any fluids on the engine. My power steering fluid is in tact. The only thing I noticed was a piece of my belt that had come off and it looks like an alien.
I have continued driving but steering is difficult and parking is impossible.
Thanks guys!
Old Jul 20, 2015 | 07:22 PM
ihscouts's Avatar
Umm, using one of the predominant hands attached to your newly ripped arms you may want to see if the power steering pump still turns. Also, check idler and belt tensioner pulleys. You'll have to remove the belt anyways to change it right? Uh, huh. Do not put a good belt on until you've found the reason why the belt became alien to it's environment........ I'll bet you a buck you have a seized bearing or missing pulley somewhere over the Rover rainbow........
Old Jul 21, 2015 | 07:38 AM
With the engine running, is your fluid churning inside of the p/s bottle?
Chances are pretty good your pump has failed, kind of common.
One way or the other you must change your belt before it breaks and you loose your alternator.
If the pump is bad, don't buy a rebuilt, the failure rate is very high, try British Parts of Utah.
Drillbit
Apr 4, 2014 02:10 PM
DiscoRover007
Jan 17, 2012 12:34 PM
xb70valkarye
Mar 30, 2009 07:15 PM
millejdq
Dec 6, 2007 12:23 PM
Deano
LR2
Aug 10, 2007 10:06 AM
