Sponsored by: CARiD
Premium gas? is it a must?
Old Mar 11, 2011 | 09:16 AM
apinky96's Avatar
Default Premium gas? is it a must?
Fairly new Land Rover lover, recently purchased a 1998 p38 and the original owner said he has only put premium gas in it. I have been doing the same since i have had it but was wondering if it is truly beneficial to keep feeding her premium? (especially when gas is looking like its going to continue going up)
Thanks
Old Mar 11, 2011 | 10:27 AM
yloDiscoII's Avatar
Yes it is worth it and it is a must, your Rover will die a slow, painful and very expensive death if you put low grade gas in it.
Old Mar 11, 2011 | 11:37 AM
hilltoppersx's Avatar
agree 100%
Old May 2, 2011 | 02:01 PM
dregill's Avatar
Default premium gas
First of all, I do use premium and will continue to use it when I can. That said, my RR is a'98 and waiting for a new engine. But, these engines are a very old basic design and can run on regular without much problem. When I bought my LR2, my salesman leased one and said he was using regular. I got 2-3 mpg better than he did and mostly drove 5-6 miles per trip up and down three good sized hills, while he drove 15 miles mostly on interstate. In other words you don't save $$ by using cheaper gas.
Old May 2, 2011 | 04:57 PM
yloDiscoII's Avatar
The LR2 has a completely different motor, so comparing what gas to use in one of those to a DII or a P38 is apples and oranges. You might want to read up about WHY premium fuel is REQUIRED for the 4.0L and the 4.6L Rover V8's before giving advice to the contrary.
Old May 2, 2011 | 05:19 PM
photocrimes's Avatar
Unless you consider your motor as a disposable, yes.
mwindth
May 20, 2014 10:50 PM
sloppyjoe
Nov 7, 2008 10:03 AM
pblake4
Feb 7, 2008 07:21 AM
bdud98disco
Jul 11, 2007 08:02 PM
