Sponsored by: CARiD
Problem with intermittent stalling at low or high speeds – 1998 Disco
Old Jan 9, 2013 | 08:31 PM
I am going to bet that you dont have catalytic converters or O2 sensors.
Do you even have a check engine light on the dash?
I had to Google your country to find out where you are. lol
Keep us posted on what you find.
Old Jan 10, 2013 | 05:15 AM
threalassmikeg's Avatar
I would start with the basics first. When is the last time you replaced your
fuel filter? have you checked the fuel pressure, or just drained the tank from the fuel rail?
Why don't you shoot us a photo of the engine so we can be clear what engine
and EFI system is installed since this is not NAS spec.
There should also be some sort of emissions decal on the radiator support
You should have an obd connector somewhere and you should have stored fault
codes.
Cheers..
Old Jan 10, 2013 | 10:28 AM
jafir's Avatar
codes.
Cheers..
He said something about a 3.9L, I wonder if he's got a distributor. Even so, there should be the box with the LED display. Is it under the seat on disco's like it is on the RRC?
Old Jan 10, 2013 | 07:50 PM
Yes he said he had the 3.9, which has a dizzy.
It might have carbs, but I am betting it is fuel injected, no cats, no O2's.
It should have the code reader box under the passenger seat, but it could have been removed.
The 3.9L was used in ROW until the introduction of the DII in 1998 as a 1999 model year.
There was also a 4 cylinder double overhead cam engine for the DI in ROW.
SCIGONE
LR2
Nov 26, 2018 12:09 PM
omarica7
Mar 11, 2014 08:12 AM
bhorwhat
Jan 13, 2010 02:15 PM
VikingDiesel
May 17, 2009 10:27 PM
klh113
Sep 18, 2007 10:34 AM
