Question about Fuel Pump
Did you try resetting the inertia switch? That's when fuel pump gets cut off during a collition and will totally disable the pump! Same as if you replace the fuel pump, this switch needs to be re-set!
reset inertia switch. installed new relays. checked fuses. fuel pump kicks in for a few seconds when the key is turned. engine still turns over but does not start. still acting like it is not getting fuel. spark plugs and wires are about 1 year old (less than 5,000 miles).
this has me stumped. any ideas would be greatly appreciated, as the nearest rover shop is a 5 hour tow.
thanks.
thanks.
Finally got some time to work on the old rover. Turns out that the fuel pump does not kick in when the key is turned. If I hot wire the fuel pump it pumps, otherwise it does not do anything.
I have installed new relays, checked all of the fuses. Inertia switch is set. Still not running.
Any ideas on what I should be checking next?
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
atikovi
04-07-2007 03:27 PM
