Sponsored by: CARiD
Radiator Hoses
Old Apr 18, 2012 | 05:49 PM
threalassmikeg's Avatar
Great, thanks for the help gentlemen. I read somewhere that the cooling system hoses were subject to a recall several years ago and that a complete set of hoses was available at the LR dealer for around $80. Is that still the case?
Those hose kits may have been $85.00 during the recall. You could check at the dealer but I would guess that the price has gone up since Land Rover is not footing the bill anymore.
A complete set of hoses at the dealer for $80? LaughOutMotherTruckingLoud!!
If you can get a complete set of cooling system hoses for your truck from the dealer then you are a very lucky person.
A little info on historic warranty pricing when Land Rover was footing the bill for R380 transmissions (Circa 1995)
They dropped the warranty price to somewhere around $585.00 complete!!!
Here's the part number of the hose kit... call the Stealership for a price.
PDK000020KIT................................Hose set complete 1
You may just get lucky!
Old Apr 18, 2012 | 09:04 PM
Danny Lee 97 Disco's Avatar
On the DI, you should be using the green antifreeze. I prefer the Prestone premixed 50/50. Prestone is a top brand if not the top brand in antifreeze and if you purchase at either Walmart, Kmart, Target, PepBoys or one of the larger chain aotomotive stores you will get a competive price.
Do not use DEXCOOL (orange stuff) due to potential problems reacting with aluminum or something to that effect. Green is good for DI.
Happy to help out.
Old Apr 19, 2012 | 08:22 AM
jbunner's Avatar
I called AB and they said Dexcool. I had looked at the Peak global lifetime because I was afraid I wouldn't get all the old stuff out. It is pinkish now. I always used Prestone in my other cars but wasn't sure about this one. Thanks for the info.
Old Apr 23, 2012 | 06:01 PM
jbunner's Avatar
I had the rover towed to a local shop to replace all the hoses and the thermostat and they said they had to remove the alternator..that didn't sound right to me. I thought it was near one of the hoses. Couldn't find exact method or any good pics. Any thoughts?
Old Apr 23, 2012 | 07:22 PM
I would have thought you could get to it from below. The lower hose has branches, one runs over to a metal riser that leads to the heater core. The others run to water pump input, and coolant reserve container. Probably should not add more than 1 hour to the labor charge.
Attached Thumbnails Radiator Hoses-p1120450.jpg   Radiator Hoses-p1120443.jpg   Radiator Hoses-esr1819.jpg
File Type: pdf
Old Apr 23, 2012 | 09:42 PM
jbunner's Avatar
Thanks, I guess I have small hands and more patients than they do..lol. I always worked on my other cars without taking them all apart. I haven't done much except tune-up stuff on my rover. I just put a new alternator and belt on right before winter and it didn't take 10 minutes except for the 30 minutes I spent looking for the bolt.
Old Apr 24, 2012 | 06:39 PM
jbunner's Avatar
Well, happy to say I got my hoses/thermostat replaced and radiator flushed. Looks like I finally found someone who knows what their doing. It was major gunked up, real thick mess. He even cleaned the engine for me. Cost me more than I thought, but everything seems to be tok--knock on wood. At least I didn't blow a head gasket.
TRIARII
Aug 6, 2014 12:40 AM
sickws6
Nov 26, 2011 05:11 PM
beebe
Apr 21, 2010 12:38 PM
hzuni
Jan 10, 2006 12:31 PM
