Sponsored by: CARiD
Radiator, AT & Oil cooler line replacement
Old Mar 29, 2016 | 08:11 PM
murray97DI's Avatar
7th Gear
That makes sense to me. This is why I was thinking the aux cooling fans were important to be operational, especially at idle or at slower speeds when temps are hot. I'll check out their site and see if I can find used fans. Thanks again for the suggestions.
Old Mar 30, 2016 | 10:30 AM
AbnMike's Avatar
The Nissens radiator is also available on RockAuto.
I, too, am trying to chase down a weird leak on my 1996 as you can see from my thread in the Discovery 1 section.
Old Mar 30, 2016 | 10:56 AM
WaltNYC's Avatar
Start small. The fans kick on when a certain temp is reached or the A/C is on. Start there with some inexpensive versions and then work your way to the radiator. If it has been acid flushed and doesn't leak, it may be too far gone, but do the fans first to confirm. They do most of the work while idling. Also, check to see they are wired correctly. One contributor here discovered that a prior owner had wired them backwards and they were pushing air away from the rad rather than towards it.
Also, you will get more eyes if you post this in the D1 section of this site rather than the 'general' section.
Finally, although your user name makes it pretty clear, it is always best to put the year and type of truck in your signature line so folks can better understand.
Beaulim
May 2, 2014 08:03 PM
wheelgarage
Dec 29, 2012 01:50 PM
javven
Jul 15, 2012 10:09 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
