Sponsored by: CARiD
Radio/Bluetooth/reverse sensors
Old Jan 26, 2025 | 04:29 AM
Cork disco 4's Avatar
Default Radio/Bluetooth/reverse sensors
Hi,
im looking for some help
my 2012 discovery 4,
radio won’t turn on. Bluetooth won’t work.
reverse sensors won’t make noise.
could this be the audio module?
any help appreciated please.
keith
Old Jan 26, 2025 | 12:25 PM
Elzot's Avatar
Originally Posted by Cork disco 4
Hi,
keith
For any electrically controlled item issue (and pretty much everything is electrically controlled) the first thing to do is check the battery's condition. This is especially true when multiple issues appear simultaneously. With the engine off, if the battery is showing less than 12.5 volts, charge the battery. (The vehicle starting normally does not rule out the battery, nor does the lack of a battery warning in the instrument panel).
I have had a number of weird malfunctions related to a weakening, but still working, battery.
Old Jan 31, 2025 | 07:49 AM
WaltNYC's Avatar
blown fuse? check the owner's manual for fuse description/function
Old Feb 1, 2025 | 01:18 PM
sisrover's Avatar
It could very likely be the audio module, as it controls the radio, Bluetooth, and reverse sensors. Check the fuses first to rule out an easy fix. If they’re fine, the module might need repair or replacement. A diagnostic scan could confirm the issue before spending on parts.
Rbbopa71
Freelander
Jul 5, 2023 05:47 PM
H Mac
LR4
Mar 9, 2023 07:21 AM
chloe.hooper@hotmail.co.uk
LR4
Nov 7, 2022 10:04 PM
TriggerPuller
Mar 23, 2018 08:23 PM
fanatic516
Apr 27, 2008 10:06 PM
