Sponsored by: CARiD
Range Rover leaky water pump.
Old Sep 27, 2007 | 02:45 PM
steveyogi's Avatar
Default Range Rover leaky water pump.
I can't seem to figure out why my 1995 4.0 Range Rover leaks around the water pump. I have taken it out and put a new gasket on. I'm loosing just a little water/anti freeze but can't completely identify how and where. It seems to happen more when the carhas run fro a while and the cooling system is under pressure.From my best quess it is coming from the right side of the pump when facing the engine from the front. I'm suspecting it could be coming from the bolts that passcompletely through the engine block but cannot verify this. I'm guessing there is a trick to sealing the water pump that I don't know about. I have never had this much trouble fixing a leak on a water pump! Help
Old Sep 28, 2007 | 12:19 PM
Landzu's Avatar
Default RE: Range Rover leaky water pump.
I had the samething on my 4.0 I used water pump sealent that nevers hardens,
its made for water pump gaskets a black looking stuff in a can, it worked.
A auto parts store will know the name of it.
FlyingZebra34
Apr 18, 2014 02:00 PM
ajhenry
Aug 17, 2011 09:58 PM
kenk
Aug 1, 2010 09:40 AM
bonez
Feb 26, 2010 04:36 PM
lipadj46
Aug 1, 2009 08:39 PM
