2003 Range Rover Water Pump Replacement
Old Aug 16, 2011 | 08:00 PM
ajhenry's Avatar
3rd Gear
Default 2003 Range Rover Water Pump Replacement
Hello All
Hellllllllllllpppppppppp!!!!!!
Im new to the site and need some help asap!!!!
I have a 2003 Range Rover big body and my antifreeze is leaking really bad and the mechanic states I need to replace the water pump. Can someone help me with some instructions on how to replace it. Do I need to replace any hoses with it
Also i found one one the web for $200, would that be about the right price for the OEM replacement.
Thanks much
desperate
antwanjhenry@hotmail.com
Chicago, il
Old Aug 16, 2011 | 10:39 PM
socalrovershop's Avatar
depending on mileage those hoses are known to blow especially the top hose. that water pump is pretty basic just make sure you replace the water pump oring seals to the rear coolant manifold pipes. remove fan shroud and fan, remove pulley and remove belt. its pretty basic after that. couple bolts and it comes off.
Old Aug 16, 2011 | 10:40 PM
make sure to get a new seal for the tstat as well
Old Aug 16, 2011 | 10:54 PM
And don't forget to download the free set of factory tech manuals called the RAVE, covers most years of most Rovers.
Old Aug 17, 2011 | 09:35 PM
ajhenry's Avatar
3rd Gear
Default Water Pump Replacement
Thanks for all your help, do you know of a good site for me to get the original water pump from... I see a lot of cheap ones and expensive one... Which do I chose, or do I just match the part number #8510324 from the dealer
Thanks [
QUOTE=socalrovershop;262863]depending on mileage those hoses are known to blow especially the top hose. that water pump is pretty basic just make sure you replace the water pump oring seals to the rear coolant manifold pipes. remove fan shroud and fan, remove pulley and remove belt. its pretty basic after that. couple bolts and it comes off.[/QUOTE]
Old Aug 17, 2011 | 09:58 PM
Check out sites like Rock Auto and AutohausAZ, compare prices with traditional guys like Atlantic British and Rovers North and bputah (british parts of utah).
West Slope Rover
Aug 20, 2010 07:19 AM
West Slope Rover
Aug 14, 2010 08:07 AM
lipadj46
Jul 8, 2009 03:58 PM
Jawbox
Mar 10, 2009 07:29 PM
bigugly82
Mar 27, 2008 04:12 PM
