Sponsored by: CARiD
rave download
Old Jun 2, 2013 | 09:31 PM
robersonb's Avatar
Default rave download
So my computer crashed since the last time I used the RAVE. I have the manual but I redownloaded the RAVE then went to extract all which seemed to work. However when I opened it, it just has a bunch of files listed and go into the setup one and it basically does nothing. What am I doing wrong?
Old Jun 2, 2013 | 09:35 PM
Did you go to one of these below? If your files are pdfs, That is waht I use, without any "front end" screen. Example - open directory "LJ" which covers D1s, and open "wmlje97.pdf" for the workshop manual.
Old Jun 2, 2013 | 09:38 PM
robersonb's Avatar
I got it from this site which is where I thought I got it from before.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
I will try yours. I would think the above was it since it took it over an hour to download.
Old Jun 2, 2013 | 09:42 PM
robersonb's Avatar
Actually after going through it a little more, I think it is all there, you just have to filter through the files, found the overhaul pdf it just didn't make it one neat little book that opens when you open up the file.
Old Jun 2, 2013 | 09:43 PM
great. In the cubby link I have there is a directory of ECU manuals, you can download the Bosch.
robersonb's Avatar
I'm working on the DII (head gaskets) which would be the v8e? I think.
Old Jun 2, 2013 | 09:44 PM
robersonb's Avatar
Ahh, much easier.
Thank you.
Old Jun 2, 2013 | 10:21 PM
jafir's Avatar
The main menu is a pdf file name rave-lr.pdf
Open that in acrobat reader and it should give you a list of stuff you can click on.
Old Jun 2, 2013 | 10:36 PM
robersonb's Avatar
Thanks, I did finally find that file and was currently reading through it for my HG repair. Gotta get ink for the printer as I usually print off the pages on the current repair I'm doing so I can have it in front of me.
big will
Dec 16, 2018 12:53 PM
texmanmoore
Mar 3, 2016 12:34 PM
NiteTrain
Aug 26, 2010 06:07 PM
camgkh
Jun 6, 2010 07:31 AM
audiS4S6
Apr 23, 2010 05:34 PM
