Rear Brake bulb replacement
I've got a Disco 98. The left rear Brake light is out. I removed the inside panel and unplugged the wires from the fixture. Does the Brake bulb twist out from the rear or do you need to remove the two wingnuts and fixture to replace the brake bulb. I can barely reach in there with my hand much less see what is in there. Thanks for info if you've done this simple little job.
