Sponsored by: CARiD
Rear Brake bulb replacement
Old Apr 19, 2009 | 12:39 PM
Madison Francis's Avatar
Default Rear Brake bulb replacement
I've got a Disco 98. The left rear Brake light is out. I removed the inside panel and unplugged the wires from the fixture. Does the Brake bulb twist out from the rear or do you need to remove the two wingnuts and fixture to replace the brake bulb. I can barely reach in there with my hand much less see what is in there. Thanks for info if you've done this simple little job.
Classklown90
Aug 21, 2010 07:24 PM
cocca
May 18, 2010 08:16 PM
goldfishy
Jan 23, 2008 03:46 AM
burtondr
Oct 20, 2007 05:19 PM
