2007 lr3 Tail/Brake Lamp Bulb Replacement
Old Jun 20, 2009 | 06:20 PM
cocca's Avatar
Default 2007 lr3 Tail/Brake Lamp Bulb Replacement
Hi. How do I replace the brake lamps on a 2007 LR3?
Old Jun 22, 2009 | 11:40 AM
drzjoint's Avatar
screws on the side I beleve philllips
Old Jun 22, 2009 | 05:06 PM
Rippin'AV's Avatar
If its anything like the older models, open up the tailgate and you should see the two screws. Pull the entire light assembly out towards the rear. Make sure you use the right replacement bulb. Good luck, should take 5 min. max.
Old May 18, 2010 | 01:18 PM
05LR3's Avatar
Default 05 Brake Lamp replacement.
I tried this the other day with no luck. I removed the two screws and pulled the light assembly out toward the rear but something else is holding it to the body. Any advice?
Old May 18, 2010 | 08:16 PM
roverguy7's Avatar
pull harder... or get something that wont scratch the paint, there are two securing pegs on the outside of the lamp, they pop out towards the rear
jfall
Oct 5, 2013 11:19 AM
Peter Van Slyke
Sep 3, 2013 07:39 AM
DiscoRover007
Aug 26, 2012 10:48 AM
kpl1228
Feb 19, 2012 07:33 AM
JBRIII
May 25, 2010 05:28 PM
