Relay Malfunction in Pos 2
I recently replaced my ECU in my 98 Disco 1. It's run fine for about 6 weeks. Literally, no problems. Suddenly, when turning the ignition to position 2 I hear a rapid clicking in a relay located under the dash on passenger side, near to the alarm module. I also hear what sounds like a fan running in the engine compartment. Very strange. In position 3 the starter will turn but the engine won't crank. I've swapped relays and it happens in the sme relay position (eve with new relay). Could this be an ECU problem or something else?
asat
11-03-2008 09:59 PM
