Sponsored by: CARiD
Replaced Engine
Old Mar 28, 2013 | 07:14 PM
laz57's Avatar
Default Replaced Engine
My mechanic replaced the 4.0 in my 96 Discovery with a 4.0 from a 97. He checked all connections and couldn't get it going. He replaced the ECU (at his expense) and could get it to turn over but not start, He said it may need to be programmed so the ECU recognizes the engine but I'm clueless. Any suggestions?
Old Mar 28, 2013 | 07:21 PM
Have him double check the crank position sensor. If it is not spaced correctly, or the teeth of the reluctor wheel are bent, there won't be spark. Back of engine, driver side. Spacers and such are frequently not put back correctly, spacing is critical. Also won't work if unplugged.
Old May 29, 2013 | 04:50 PM
Charlie_V's Avatar
I replaced my engine and had the same problem... it was the black inertial switch on the passenger side firewall. I literally said "what's this," punched the button on the top (reset), and it fired right up. https://landroverforums.com/forum/di...s-55396/page2/
Mine is a Disco II but I think they both have the switch.
Old May 29, 2013 | 05:56 PM
Indeed they do. Kills fuel pump.
couzteau
Mar 14, 2012 07:32 PM
2000 Disco II
Jul 25, 2011 08:10 PM
kylelind
Feb 24, 2011 07:35 AM
AK Rover
Jul 15, 2010 07:11 AM
