Sponsored by: CARiD
Replaced Valve Body Solenoids......Won't Start!!!
Old Dec 29, 2019 | 08:38 PM
yockstar's Avatar
Default Replaced Valve Body Solenoids......Won't Start!!!
.....my continued thanks to the this invaluable community; the ideas, support and guidance is amazing. Now with my dilemma. Quick description of my challenge:
2005 LR3 HSE 4.4 approximately 176K miles, Coil springs
I turn my key and nothing. Lights in the dash cycle and light up as normal (no warning indicators). I here a soft click underneath the passenger side dash....and no crank what so ever. Once I put my key in, I cannot get my key out, without disconnecting the battery. That is my current state, and this is how I arrived to this point.
- I ordered replacement set of OEM Solenoids to correct a shifting issue and transmission fault that I received. I also thought I would take this opportunity to change over the trans fluid, sleeves, and covert over the trans pan/filter. I made the switch of solenoids, and when I placed the valve body back into the vehicle, closed up the tranny pan, and went to start the car to get the trans oil up to temp specs for adding the remaining 2 quarts, I saw a big fat "E" in the dash, where I used to see a "F". The only thing that had changed was the solenoids, so I quickly went to work taking the valve body back off, and going back with my original solenoids.
-Back to my original solenoids, with fresh filter/pan & sleeves, and when I placed my key in to turn the ignition on, I noticed that the dash indicated that the car was in D, but the shifter was still in park.....? I could not get the car to shift either out of park, and turning the key did nothing for me. The big fat error code of E was gone, but the car would not crank. I implemented the gear shift manual shifter through the side of the shifter and was able to slide the shifter through the gears. I went up and down the shifter column about three times, and stopped at N (nuetral) and wallah, I saw the "D" disappear from the dash, and feverishly began to turn the key........Virrrrrooooommm!! I am in business. I felt on top of the world, and breathed as if the worst was behind me. Assuming everything was fine, I turned off the car and went to clean up my work space. Yep, the key would not come out, and I went to start the car back up, and nothing.
Fast forwarding through my moments of depression/defeat and three days of research, this is what I have ascertained and done. I noticed the key that I used had become deprogrammed, as it no longer would lock/unclock the doors remotely, so moving forward I used a spare key (odd??).
1. Checked all my fuses in the engine compartment and passenger compartment. Took my battery in for inspection, and it was bad, so swapped out a new battery, and made several attempts to start it with a new battery and with jumper cables from another car (to ensure proper voltage).
2. Disassembled the gear shift, cleaning the electrical connectors (all of them) with electric cleaning fluid. checked to see if the shifting of the gears actually corresponded with the movement capacity of the truck. Put it in reverse, and then pushed it back....put it in park and tried to push it...etc. It checked out physically, but at this point, no gear indicators show up on the dash at all (PRND....). If i put it in D and sport mode, the word "sport" does show up on the dash.
3. Clean the entire front cabin space of the truck (i mean vents and hidden cracks/spaces as well), just cause I was out of ideas and needed to feel successful.
4. Hooked up my IID Tool and flashed all the ECU's, clearing out any faults and did my best to reset the BCU. I tried to reset the transfer case and got the error code "E 0" on the IID Tool....??
I am now convinced that I must have overlooked something in placing the valve body back into the tranny housing. Is there anyone who is familiar with taking these in and out, and can extend some possibilities of what my be either not engaged or not tightened that would cause the truck not to recognize what gear it is actually in? My assumption is that the LR3 thinks it is D still, and that is why every time I put my key in, I can not pull it out. I must say that when I hooked the harness up to the valve body sleeve, it did not go as smooth as it has gone when I have done it on other LR3's. This is the first time I have every taken the valve body off, normally I would just do trans pan conversions and valve body sleeve replacements. It rained the last 20 odd hours, so I have not been able to get back under the truck. I am going to go step for step in analyzing the connectors involved with the valve body, taking careful examination of the gear linkage (although it shifts fairly smoothly) and rub a rabbits foot along the outer edge of the pan for mercy from the maintenance gods.
Is there any cables that I might have loosened, or interrupted on the valve body, to keep it in a state of D (Drive)....or is there another area I should be investigating all together....??
Last edited by yockstar; Dec 29, 2019 at 08:50 PM. Reason: Not sure if this is being listed in the proper section, LR3 troubleshooting..??
Ron6977
Feb 22, 2013 12:29 PM
hilltoppersx
May 25, 2011 08:11 AM
grandkodiak
Apr 2, 2011 10:56 AM
tiredone
Feb 23, 2009 12:12 AM
