replaced vss etc...speedomter question
Old 02-26-2012, 01:50 PM
best4x4byfar's Avatar
You thought correctly...Higgs Boson: 1998 Land Rover Disco...my thinking then is perhaps the cruise con is the interrupt....or perhaps does not need the continuity in speed out...as with most things British...enigmatic as to why they chose to make such a beautiful mechanical truck poisoned by electronics...
Old 02-27-2012, 12:40 PM
Rovin4life's Avatar
how is the battery and the charging system? And is the vehicle's belt installed correctly.
Old 04-08-2012, 08:36 PM
Update: Turns out it was a bad relay...aftermarket relay that was shorting out and not conveying info to cluster.
Old 04-08-2012, 09:08 PM
What an expensive relay that proved to be!
kog50
08-19-2023 10:23 AM
achapman
06-25-2013 03:40 PM
06Range
05-08-2013 09:01 PM
Maytag
07-02-2012 09:30 PM
TheBelly
11-01-2010 08:34 PM
Quick Reply: replaced vss etc...speedomter question
