Sponsored by: CARiD
Replaced xyz neutral switch
Old Jul 9, 2016 | 11:10 AM
asyyz's Avatar
4th Gear
Default Replaced xyz neutral switch
Hello,
I recently had the xyz switch replaced on my Discovery ll because of flashing lights on the shifter/dash etc. It runs fine now but as we were driving it bucked and jerked for about 2 seconds. Check engine light flashed too. We have always maintained this vehicle. Any ideas as to what could be up?
__________________
2003 Discovery ll, 100,000 miles
Old Jul 9, 2016 | 07:03 PM
chubbs878's Avatar
Check the fill level of trans fluid?
Old Jul 9, 2016 | 08:14 PM
Racer X's Avatar
Flashing Check Engine light is almost always a misfire.
When is the last time a tune up was done? What plugs/ wires were used?
Old Jul 12, 2016 | 12:52 PM
mln01's Avatar
Al, you'll get more responses if you post in the Discovery Series II forum.
That said it's important to get the codes read that are causing the check engine light to appear. Otherwise you're just guessing. For misfires it's more often a problem with the ignition wires or the spark plugs than a failure of one of the coils.
asyyz
Jul 9, 2016 10:56 AM
rotowaypilot
Apr 3, 2016 06:12 AM
willieg
Jan 31, 2015 04:37 AM
hilltoppersx
May 25, 2011 08:11 AM
RicknCody
Mar 28, 2010 07:49 PM
