Sponsored by: CARiD
Replacing the head gasket on 1997 RR SE
Old May 7, 2013 | 09:11 PM
dirklemond's Avatar
Default Replacing the head gasket on 1997 RR SE
Has anyone replaced a blown head gasket on the 4.0 RR engine without doing a block test?
Old May 8, 2013 | 09:14 AM
drowssap's Avatar
same block as a Disco so I will say yes
Old May 11, 2013 | 10:28 AM
dirklemond's Avatar
So, it is not necessary to do a block test when changing a blown head gasket. It's a good idea, but not a must do?
Old May 13, 2013 | 08:00 AM
drowssap's Avatar
Old May 13, 2013 | 08:11 AM
I would guess most DIY HGs are without a block test (using shop air pressure, not the $50 chemical test).
Head gaskets give hints - like:
White smoke out exhaust
Overheating
Hoses rock hard
coolant tank boiling
coolant in oil
coolant leaking from gasket external
Cracked block can mimic many of those
The "odds" are that if you have misfires or leaks in the front or rear cylinders it is HG, and inboard cylinders could easily be cracked block leaking behind a sleeve.
The must do is a machine shop check of heads for flatness, 0.002 inch.
After you have done all that, $300 for parts, a couple of weekends with the wrench and breaker bar; and machine shop work; you would be most unhappy if a cracked block was there.
There are also products like KSeal and Irontite to consider. As well as a top hat sleeved block from an engine rebuilder.
GiGi La Luz Ramone
Aug 31, 2013 04:46 PM
C130Driver
Aug 21, 2012 09:32 PM
Beamer1
Apr 22, 2012 01:07 PM
youvegotwood
Mar 20, 2010 01:50 AM
cleopard
Oct 21, 2009 10:19 PM
