Sponsored by: CARiD
replacing lug bolts....any ideas
Old Apr 13, 2012 | 12:42 PM
filbs's Avatar
Default replacing lug bolts....any ideas
I have two on my left rear and one on right rear that were stripped and are now useless.... I am staying off the highway.........What is going to be my best solution to fix this problem............
Old Apr 13, 2012 | 12:46 PM
filbs's Avatar
should I just try to pull some hubs from a junkyard with good studs on em? I think this is the route I will take..........What other models will the hubs interchange off of? RRC? D2? there are several D2's and rang rovers being parted out near me so if these will work PLEASE TELL ME
Old Apr 13, 2012 | 08:15 PM
Why not just replace the studs?
Can the threads be chased and cleaned up to work again?
RRC and DI are the parts you need.
Old Apr 13, 2012 | 10:58 PM
filbs's Avatar
one is literally broken off and the other two are beyond repair..................if I bought just the studs I would have to pay someone to install them right? I don't believe I have what is required to do it properly..... I think replacing the entire hub would be cheaper.... Spoke with Paul and he was willing to ship the two hubs for 80 bucks... don't think I can beat that.....
Old Apr 14, 2012 | 11:58 AM
Rovin4life's Avatar
the hubs take alot more work to replace. just get one hub and knock them out. just make sure to put a nut that matches the thread on to reduce the effect of the hammer. then knock it out, and then use the same nut or another one along with some oversized washers and larger nuts to pull it thru with the nut. its easier with a air gun but it can be done by hand.
tigertrakstar1
Mar 5, 2014 04:13 PM
rsomp
Jun 14, 2012 12:45 PM
C Trus
Oct 30, 2011 11:25 AM
bcolins
Apr 19, 2011 06:40 PM
sna77
Jun 15, 2007 10:43 PM
