Sponsored by: CARiD
Replacing original Lucas 35DM8 with Petronix replacement
Old Nov 5, 2019 | 11:43 AM
Oregon Discovery1's Avatar
Default Replacing original Lucas 35DM8 with Petronix replacement
I have a 95 disco with the ignition module not attached to the distributor, the only replacement distributor that I found and purchased has a ignition module attached to the side of the distributor.My questions is can l remove the new ignition module and wire into the original ignition module that is next to the coil
Old Nov 5, 2019 | 08:10 PM
Best4x4's Avatar
On newer Dizzy's the amplifier mounted to the side is usually a dummy and then the actual amplifier is mounted remotely by the coil on a bracket.
Roverfanatic
Jul 31, 2018 02:04 PM
Mattwyckoff1
Dec 6, 2017 10:44 PM
Mattwyckoff1
Dec 6, 2017 10:28 AM
stevee
May 17, 2017 08:05 PM
ruggles
Feb 11, 2011 11:13 AM
