Sponsored by: CARiD
Replacing SRS ECU
Old Apr 25, 2018 | 10:11 PM
commandos99's Avatar
Question
Originally Posted by Judgey
UPDATE: Managed to source a second hand srs ecu for £40, stuck it in and no more light
Hi Judgey,
Sorry to revive this old thread but my 2004 2.5 V6 FL has similar issue that scanner read SRS DCU come back with "Internal Fault(replace SDM)", and SRS light on the dash won't distinguish following pre-ignition bulb check of 5 sec. I have also cut the under heater-assembly carpet and sourced a second hand YWC000610 DCU off the ebay. I have a few queries that need your kind confirmation before I start my attempt to diy:
2. did you remove the heater assembly or by removing the carpet there would be enough room for the swap?
3. the swap is like a direct fit without any programming involved?
Thanks a lot.
rravenn13
Jan 10, 2025 08:57 PM
me6067
Jun 18, 2015 11:02 AM
Paul Grant
Aug 10, 2014 12:29 PM
DiscoJonny
Apr 28, 2012 07:21 PM
