rough running
It could be the valves making the knocking sound and this could cause black smoke on your exhaust if it goes bad.
hp?act=post&do=rehp?act=post&do=re
Autopartswarehouse kurt E. daniel
rum/forumdisplay.php?f=1/key_/
Check or replace your plugs and wires, same with the cap and rotor. Do a compreson test to rule out valves, check for vacuum leaks, consider decarboning the engine and check your timing.
dillhole
Feb 20, 2020 02:30 PM
