Sponsored by: CARiD
running rough
Old Jun 7, 2010 | 03:57 PM
diverdad69's Avatar
8th Gear
Default running rough
92 county, driving down the road and it feels like its running out of gas but its not, punch it and it will run ok, then no power in the pedal, shift to low 2 and it runs good ? any suggestions? almost like it has no power, but starts fine idles fine....but ?
Old Jun 7, 2010 | 06:18 PM
So, what have you checked so far, when was it last tuned with cap/rotor along with wires, what octane gas are you using and when did you last change your fuel filter.
Old Jun 8, 2010 | 10:00 PM
LANDROVER LUKE's Avatar
check fuel pressure?
how old is the fuel filter?
check for rust at the fuel rail by taking the lines off--these oldies but goodies are prone for rust and heavy debris getting into the injectors
Old Jun 9, 2010 | 08:00 AM
diverdad69's Avatar
8th Gear
well my second alternator in 5 weeks was the problem, it was putting out very low voltage to none casuing all the problems, when it was running good i was gunning it....increase in voltage output. the fuel system, rails, filter etc has not been checked since i owned it 2 months, i have been dealing with many more issues on it first which the extensive list is coming to a close and regular maint is soon to begin....thanks everyone
Sean
Old Jun 17, 2010 | 12:44 AM
james1's Avatar
3rd Gear
When you add cleaner to a engine you should run it till it get`s hot , it`s popular to it injector cleaner when your going to travel because the injectors and the engine gets really hot burn off the carbur builted -up.
dillhole
Feb 20, 2020 02:30 PM
sidneype
Sep 10, 2008 07:49 AM
PMROBERTS
Sep 29, 2005 11:50 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
sidneype
Jun 30, 2005 07:21 PM
