Sponsored by: CARiD
Sad... Frame Rot
Old Oct 26, 2010 | 07:21 PM
Are you 1000% SURE he swapped the frame only and not the body?
It would be very easy to pull your body off and place it onto another rolling chassis that was in better shape than yours frame rot wise but had 200,000 more miles on it than yours did.
Old Oct 27, 2010 | 10:20 AM
Charles68's Avatar
Default frame
It was frame. I saw it get delivered. When he lifted everything off I saw old/new frames side by side.
He then reassembled everything back on to new frame.
Old Oct 27, 2010 | 06:50 PM
Ok good.
I was worried that you had gotten royally screwed.
Old Oct 27, 2010 | 11:18 PM
Charles68's Avatar
Default i probably did
I probably still did get screwed.
I don't believe in coincidences.
No bearing hub problems and not three amigos before switching frames. First day driving with new frame i hear grinding off and on. Continues for a few days of light around town driving. My wife hear big crunch while driving, gets three amigos, and we take it straight to shop.
The frame job must somehow connect to the hub failure.
No?
On the bright side the air suspension finally fixed. It was the valve next to the compressor. Slow leak. New valve all is well.
andrew12159
Mar 30, 2019 03:13 PM
cogsley
Aug 13, 2014 03:24 PM
sparkleberry
Nov 5, 2012 09:54 PM
Spike555
ROAMING WITH FRIENDS
Oct 26, 2011 02:54 AM
suzmac7
May 14, 2007 10:39 PM
