Sponsored by: CARiD
Searching for mythical block drain plugs
Old Apr 18, 2008 | 08:51 PM
wadematt's Avatar
Default Searching for mythical block drain plugs
I have been searching my engine and this forum high and low to find the block drain plugs. Are these the same as the freeze plugs? I can find the inverted plugs on each side of the block. But I was told not to remove these unless you want the headache of putting them back in. Is there some sort of square headed drain plug on each side similar to oil drain plug? I'm trying to flush the engine and I have pulled the lower radiator hose and now I just need to drain the block. However I don't want to fool with the freeze plugs.
Old Apr 18, 2008 | 11:50 PM
Bartell's Avatar
Default RE: Searching for mythical block drain plugs
ORIGINAL: wadematt
They are two small threaded plugs (sometimes fitted with valves) on both side of the engine. They will be under the exhaust manifolds in the section between the heads and the oil sump, a bit more towards the rear of the engine. Remove these.
Even with them removed, I am uncomfortable doing a flush without removing the thermostat and its housing. It is also a better idea to flush from the top rather than the bottom. That is in the normal direction of the coolant flow and reduces the risk of crud from the flush collecting in the radiator and staying there.
There are rad flush products available if you want to buy one to add to the water but I have never done so. I simply put the hose in the rad and keep in running for 20 minutes or so until it is crystal clear.
When you refill with coolant, mix with DISTILLED water.
James
Old Apr 19, 2008 | 08:05 AM
Save your self alot of unnecessary work, replace the t/stat and let the coolant drain out fro there, if you leave a little in the block there is no harm done.
Old Apr 19, 2008 | 08:07 AM
wadematt's Avatar
Okay MIke. But I'm stupid. Where is the t/stat? I pulled the hose from the bottom of the radiator on passenger side. Where would it be in relation to that? Also, I'm trying to get all the coolant out because I put the dumb dadgum green crap in and am trying to get all of that out.
Old Apr 19, 2008 | 08:10 AM
wadematt's Avatar
ORIGINAL: Bartell
James
Okay I assume I have to take the shield thingy off the top to get to the radiator to put the hose in? Or do I just put it in one of the hoses?
Old Apr 19, 2008 | 09:05 AM
Call me.
303-862-7680
abran
Nov 7, 2014 08:21 AM
DrQew
Sep 30, 2013 02:27 PM
aublec22
May 30, 2009 04:04 PM
StevenDiscoII
Jan 2, 2007 07:05 PM
Charlie L
Apr 12, 2005 05:49 PM
