Sponsored by: CARiD
Seems I have more than one problem
Old Feb 4, 2010 | 03:10 PM
HOLSTOCK's Avatar
3rd Gear
Question Seems I have more than one problem
Just purchased a '98 disco from my brother who has had it for three years with no problems. The wife was driving it and stopped at the mail box, tried to put it in reverse when something broke and made a crunch sound, dang! Got home, got it in the drive, put it in gear, front shaft spins. Must have spun a gear in the front universal. What I don't understand is I thought this was all time four wheel drive. Is it a front wheel primary drive with limited slip? Front prop spinns in what is obviously broken front universal, rear doesn't turn at all. Is there an adjustment to use rear as primary? Thanks in advance for any help I can get.
Last edited by HOLSTOCK; Feb 4, 2010 at 03:19 PM. Reason: posted before I was done.
Old Feb 4, 2010 | 03:12 PM
hilltoppersx's Avatar
download the rave manual. www.landroverresource.com
Old Feb 4, 2010 | 03:22 PM
HOLSTOCK's Avatar
3rd Gear
Thanks, Hilltopper. Will do. I did order a Haynes witch came in the same day it broke ironicly, but it just refers you to a specialist for anything to do with the universal/tranfer case, not much help.
Old Feb 8, 2010 | 08:38 PM
bmw zhp's Avatar
I thought this was all time four wheel drive. Is it a front wheel primary drive with limited slip? Front prop spinns in what is obviously broken front universal, rear doesn't turn at all. Is there an adjustment to use rear as primary? Thanks in advance for any help I can get.[/quote]
i to would like to know this as well
Old May 8, 2010 | 05:18 PM
HOLSTOCK's Avatar
3rd Gear
On the road all the time, so the wife took it to a guy to take it apart and look at it. Ended up being driver side cv joint. bearings and race destroyed. Put a new one in and she's good to go. I wasn't getting the whole "diff lock", I thought it was all wheel drive all the time. Could move it in diff lock, but without it, it just spun free. New grease pack kits for both sides and driver side cv joint and it's like new......until the next thing! HA!
psykokid
Nov 19, 2013 01:33 PM
Externet
Aug 26, 2013 06:45 PM
Discolife
Dec 2, 2011 03:44 PM
roverboy
Dec 13, 2008 04:32 PM
