Sponsored by: CARiD
service on a 2.5DSE
Old Oct 25, 2006 | 10:21 AM
Sid1's Avatar
6th Gear
Default service on a 2.5DSE
Hi All,
I'm going to doa full service on my 1997 Range Rover 2.5 DSE.
It is not showing any warning lights or anything. Its just something I want to do BEFORE the next service is due just for piece of mind and knowing its been done.
Question: Does it have an electronic service interval that needs resetting after a service?
Not sure if it has and if so how its set/reset.
Old Oct 26, 2006 | 06:17 AM
Sid1's Avatar
6th Gear
Default RE: service on a 2.5DSE
silly idiot....
Broke one of the fuel pipes coming out of the fuel filter. Couldn't work out how they came off once the wire spring was off.
Pulled a little too hard and snapped the plastic connector.
Old Nov 3, 2006 | 11:06 AM
dragon's Avatar
5th Gear
No resetting required, unless you want to reset the Trip 2 counter, if you want it to remind you of service intervals.
Just remember, diesels will hit back on you eventually, if you do not change the engine oil regularly.
Mark Bryant
Jan 30, 2012 08:57 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
adcooper
Sep 15, 2007 07:56 AM
richard49
Sep 15, 2007 07:53 AM
Rob84
Feb 7, 2007 08:49 PM
