Sponsored by: CARiD
service engine light-
Old Dec 2, 2005 | 02:28 AM
rdisco2's Avatar
4th Gear
Default service engine light-
SE light came on tonight while pulling a mild incline. Pulled P1172 and P1175 codes from the OBD. Doesn't seem to run any differently, but I did notice a slight hesitation right before the light came on. Any thoughts? Vehicle is a 2000 Disco II with 66,000 miles. Thanks for your replies
Old Dec 2, 2005 | 03:43 AM
mikemeyer0's Avatar
Default RE: service engine light-
ORIGINAL: a friend
Both of those codes indicate the engine is running too rich, and the injectors connot make up for it.
2 Likely candidates would be leaking injectors, or the MAF. Both are very possible.
hope this helps for now while I do more research
Old Dec 2, 2005 | 03:49 AM
mikemeyer0's Avatar
P1175 Lambda control adaption fault bank 2.
P1172 System Too Rich, Bank A & Bank B
claening the MAF sensor might help it out, use electrical contact cleaner and be careful, the MAF sensor is delicate.
Old Dec 4, 2005 | 02:09 AM
rdisco2's Avatar
4th Gear
will try cleaning the MAF, that would make sense since I recently installed a K&N air filter, maybe some oil buildup? Thanks for the help!
Old Dec 5, 2005 | 11:51 PM
Bait's Avatar
My crystal ball says that perhaps you did not get the air filter lid on correctly. No worries, the Factory does the the same thing.
Old Dec 6, 2005 | 10:54 AM
Landzu's Avatar
Oil type air filters and MAF sensors do not mix.
Its only a matter of time until you get a CEL.
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
