Sponsored by: CARiD
Shifting & Low Speed Questions
Old Aug 13, 2009 | 09:14 AM
sn1987's Avatar
Default Shifting & Low Speed Questions
Hi, i have some general question to low gearing of my Defender.
I have no docu (TD4) but on shielt it says 0-5mph max speed to shift to and back from low speed but not max speed.
What gears on main gearbox i can use it with and how fast can i drive?
Is there something to watch for? Is it not recommended to use? Would it be ok (aside from higher noise) to drive mostly on low gearing?
Old Aug 13, 2009 | 11:16 AM
antichrist's Avatar
Are you talking about when to use low range?
Old Aug 13, 2009 | 02:45 PM
sn1987's Avatar
yes, i meant low range gearbox, not low speed
Old Aug 13, 2009 | 05:59 PM
If you can shift into low range without moving, you are better off in that you will have less chance of blowing a gear.
High to low is hard on the gear, shifting out of low back into high is eaqsy and will cause less damage.
As for what speed you can go, go drive it, off road and watch you tach, you'll see what works for you.
Old Aug 14, 2009 | 05:08 PM
sn1987's Avatar
thank you. i tried it today and it seems to be really too low to use it often, but shifting at zero speed is mostly not possible, just move it a little and it all falls in.
Old Aug 14, 2009 | 08:49 PM
You Got It!!
Old Aug 15, 2009 | 09:17 AM
sn1987's Avatar
yea :-), definitely needs hands on...
now only need to figure out how to full collapse back seats and i can say i know my landy good :-)
hhalimi
Apr 19, 2012 07:51 PM
mwyoung
Nov 2, 2011 12:28 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
soupdogg
Sep 25, 2007 12:49 PM
