Sponsored by: CARiD
Shreaded Serpetine and Power Steering Pulley Question
Old May 7, 2014 | 07:10 PM
gundog's Avatar
Default Shredded Serpentine and Power Steering Pulley Question
So, I shredded a serpentine belt over the weekend on my 01 DII and finally got it replaced today. I got a new belt on, fired up the truck and noticed a faint rattling noise that sounded like a chain running over a metal surface. Other than that, the truck ran fine. I shut it down and looked around the engine compartment and noticed that the new belt was straddling the power steering pump pulley by 1/8-1/4". I took the belt off again so I could look at the pulley alignment between all of the components and it looks like the power steering pump pulley is 1/8-1/4" more forward than the other pulleys/idlers and is out of alignment. I looked at the attachment bolts to the pulley and the pump bracket and it looks like everything is tight. I need some help here as to what would cause this.
Old May 8, 2014 | 07:03 AM
drowssap's Avatar
two possibility one the bearing in the pump is bad allowing the pulley to move forward. the other would be the pump was replaced and the pulley was not installed all the way on the shaft.
gundog
Sep 22, 2019 10:37 PM
MntRover
Sep 15, 2013 10:01 PM
PJRover
Sep 13, 2013 05:29 AM
Rferguson
Aug 19, 2013 09:51 AM
JakeVT
Oct 15, 2011 03:03 PM
